Howdy, I have tried to connect my Arduino Nano RP2040 Connect to OpenMV in order to install the firmware, but it will not work. I put the device into bootloader mode and then attempt to connect it in accordance with documentation. The indicator on the bottom left detects there is a board but will not install the firmware. The Arduino IDE will detect the board, Thonny detects it, but OpenMV will not.
The error I get says: “Timeout error while getting firmware version!”
Any insight to the issue would be greatly appreciated, thank you!
