Just received a new OpenMV-H7 bought through Mouser (so assume it’s genuine.)
Installed OpenMV IDE, plugged in the OpenMV board and connected fine. IDE asked to update the firmware, which I did.
After the green flashing of the bootloader, the LED rapidly flashes white. So I’ve tried reloading the firmware a couple of times with no luck.
I’ve tried running the helloworld example a number of times. Sometimes the ERROR.LOG file contains:
FATAL ERROR:
name too long
and main.py contains
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
Sometimes the main.c contains something reasonable and ERROR.LOG contains:
FATAL ERROR:
Capture Failed: -4
I’m out of ideas of what to try next. Any ideas?
