Hi - I’m sending clean 5.11v into the white plug - at power on white flashes once (vs several times when I connect USB). Lately its not connecting to the network and streaming. Its been working fine for months this way. Is the single white flash correct? (i never noticed as its always just worked).
Yeah, that’s the correct behavior. What script is running on the camera?
Try this, run the “erase file system” command in the IDE and then connect the camera. This will clear off any scripts on the camera.
Yes that did the trick! Thank you! XOXO
