Hello, I updated the openMV firmware, but it suddenly doesn’t work after that. I use the RT1062 cam, did I do the wrong firmware update? The sensor lights up, but I don’t recognize the cam and try to bootload it back to the RT1062 zip file before, but it keeps getting an error saying it’s time out. Even the device manager doesn’t recognize the openMV cam. Tomorrow is the announcement, and I’m in trouble. How can I solve it? I’m really desperate. I don’t even know where the rst pin and this are because I’m a non-major. Could you kindly explain it to me once? Thank you very much.
Hi, please do this:
Attach a wire between SBL and VCC. Plug into the PC. Click connect on the IDE and follow the prompts. The IDE will help you recover it.
For installing firmware please use the Tool->Install Latest Dev firmware.
There’s no reason for you to have downloaded the firmware manually.
