I tried to Upload a New Firmware file obtained from the Openmv Github page(path=https://github.com/openmv/openmv/releases/firmware_OPENMV4P/firmware.bin) and I uploaded the file to the cam via Load firmware in the Tools section on the Openmv IDE, Now the camera is not detected only green led is glowing, I am not able to erase the data on the camera, How can I reset the Camera. Please navigate me.
You loaded the firmware for the stm32 board. Pull SBL pin high, connect the board and try to connect from the IDE, it should recover it for you.
Thankyou, It worked perfectly.
