OpenMV CAM RT1062 not detected by computer
"Hello friends, I have an OpenMV CAM RT1062. It was working before, but while I was updating the firmware from the computer, the power went out and the update was interrupted. After that, the computer stopped recognizing the device.
When I type ‘lsusb’ in the console, it doesn’t even show up.
I would appreciate your help."
“OpenMV appears like this.”
You need to put it into SBL mode.
Attach a wire between SBL and 3.3V and then connect to the IDE.
Thank you very much for your help; thanks to you, the problem has been solved.
