The OpenMV Cam RT1062 worked a few days ago. But today when I tried to connect it to OpenMV IDE on a macOS (intel) it did not work. I observed that it connects briefly, the Green LED turns on (sometime instantly while connecting, sometime it takes a few seconds to turn on the Green LED). I can see the mounted drive. After about 5 seconds it disconnects and Green LED turns off and the drive disappers.
Also, the USB enumerates if the lsusb command is executed quickly:
Bus 020 Device 002: ID 1209:abd1 MicroPython OpenMV IMXRT1060
What I have tried so far:
- used several USB C cables to make sure it’s not defective or data-only
- shorted SBL and 3.3V and tried to erase/upload firmware but it get failed due to disconnection
- connected to different computer (Raspberry Pi 5)
