I have an issue where after an uninstall and clean reinstall of openmv-ide-windows-2.6.8 the application crashes silently after closing the splash screen.
If I launch it from terminal there is no output before the prompt is returned.
The last thing I remember doing before the app would no longer launch was editting a dataset with the bimp plugin for gimp (mass cropping), perhaps both apps used the same files at the same time? Not sure. In any case, after several restarts and several redownloads/unistalls/reinstalls of openmv the behaviour is the same. Crash after splash.
Any help on how I can reinstall and get back to playing with OpenMV would be much appreciated. Thanks so much,
QC
I have the following data from the Application Log in the Event Viewer for Windows:
General:
Fault bucket 1789960522704944178, type 1
Event Name: APPCRASH
Response: Not available
Cab Id: 0
Problem signature:
P1: openmvide.exe
P2: 0.0.0.0
P3: 5fcd558b
P4: Core.dll
P5: 0.0.0.0
P6: 5fcd55e8
P7: c0000005
P8: 000468a0
P9:
P10:
\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERB479.tmp.dmp
\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERB5A3.tmp.WERInternalMetadata.xml
\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERB5D3.tmp.xml
\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERB60F.tmp.csv
\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERB66E.tmp.txt
These files may be available here:
\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_openmvide.exe_944f79964f2993225560b85ff3f24f42ce3f0f5_375c73b6_5756ba74
Analysis symbol:
Rechecking for solution: 0
Report Id: 3e6cb032-1569-4d2a-8e19-6c8a51c26cc2
Report Status: 268435456
Hashed bucket: f077174cca20015fb8d7379c9dccfc32
Cab Guid: 0
Details:
System Data:
Report.wer.txt (18.7 KB)
CrashOnSplashersSystemInfo.txt (718 KB)
