My PortentaVisionCam was working fine, and now doesn’t. What are my steps to take. Unlike most microcontroller issues, I would assume I have messed up my wires. What would your typical steps be for trouble shooting. Presently I have
The Portenta breaths green on button double press (DFU). I can install the OpenMV firmware.
On single button press the portenta connects to OpenMV and I can run example main.py which flashes the onboard green LED
The examples helloworld.py program needs RGB565 changed to GRAYSCALE which used to work but now doesn’t. Any Suggestions?
My error is: RuntimeError: Capture Failed: -4
Is there a test that gives feedback about the cameras connectivity. Sometimes it says the camera is connected, other times it says no cam.
P.S. I am really hard on software and hardware, so I could easily have done something bad.
