HI,
I finally bought the Arduino Portenta H7 and the Arduino vision shield. I have just tried to connect both of them and connect it with my computer. I wanted to connect it with the programm openmv ide, but the system just keeps on running time out. i don’t know why this happen. Can someone help me? Once i connect the board with my computer, the RGB blinks blue,tosca,green colour and repeat itself
Thank you very much for your answer.
Best Regards,
William Jiovandy
I have just updated the bootloader and it can now connect with the openmv ide. But as i click the play button, it tells me Runtime Error: Failed to detect image sensor or image sensor is detached. I tried connecting both the Arduino Portenta H7 and the Arduino vision shiled together, but it still tells me that its not connected
Thank you for your time.
Best Regards,
William Jiovandy
Make sure to update the firmware first before anything and if it still doesn’t work try running any Arduino camera example (from the Arduino IDE) just to make sure the hardware is not the issue.
Thanks for your answer. I finally work it out.
can i actually measure the LAB value if i use grayscale on openmv? because i receive 0 on A and B
Not sure I understand the question, please post a new topic about it and include more details.
I tried using sensor.set_pixformat(sensor.RGB565) on the settings for the senor, but when i run the programm it tells me that RuntimeError: Sensor control failed. I don’t know why this happens and by using grayscal can i have the value of LAB? because i only receive the value on A and B as 0.
Thank you
The sensor is grayscale only.
Is there any possible way to use the RGB565? Because i need the value of A and B to determine the color of blob
No, because the sensor is grayscale only.
Could you please clarify which firmware are you referring to ? I have a similar issue right now
Hi, please update to the latest firmware. We just released a fixed version which should make the Portenta Vision Shield work.
