No Detection: OV7670 on Arduino Nano RP2040 Connect
I ran the following code on my Arduino Nano RP2040 Connect.
# Hello World Example
import sensor, image, time
    clock.tick()                    # Update the FPS clock.
    print(clock.fps())              # Note: OpenMV Cam runs about half as fast when connected
But the camera cannot be found as in the following message.
RuntimeError: Failed to detect the image or image sensor is detached.
I have one more question. When I connected the same camera to the my Nano 33 BLE Sense, the camera was recognized, but it also showed the following error message.
File “”, line 10, in
RuntimeError: Frame buffer overflow, try reducing the frame size.
MicroPython: v1.18-omv OpenMV: v4.3.0 HAL: v2.0.0 BOARD: Arduino Nano 33 BLE SENSE-NRF52840
On the RP2040 the camera I2C needs to be connected to these pins:
SCL_PIN         (13)
SDA_PIN         (12)
This is very self-explanatory, but anyway you need to use a smaller frame or switch to grayscale.
I further checked the i2c pins you mentioned.
But it still doesn’t work. It’s strange, but it works on the nano33 ble sense board.
Can you please check the following picture?
I connected only scl, sda, power, gnd, and clock pins,
but the result is the same even if I connect all pins and test.
Do you connect the external clock pin ? pin (28)
You should connect XCLK, power down and reset:
#define DCMI_XCLK_PIN           (28)
#define DCMI_PWDN_PIN           (0)
#define DCMI_RESET_PIN          (1)
And note the I2C pins already have pull-ups on board.
Could you please share the full pinmap for OV7670 to Nano RP2040 connect?
