Following this tuto:
Getting Started with OpenMV | Arduino Documentation
I can test the correct bootloader update, afterwards I install OpenMV and basic python scripts with LEDS is ok, but when I try test the cam included in Nano 33 BLE Sense TinyML kit: OV7675 , then OpenMV in last version detects OV7690 and I cant test in QVGA resolution says overflow.
So I try with QQVGA resolution and it compiles but represented image in viewer is like this:
Hi, that platform has limited memory. So, it’s not going to be able to do a crazy amount of things.
Anyway, regarding the image, I don’t actually have one of those kits. Is the camera a separate module? If so, are all the wires attached to it correctly?
Ah, then it should indeed work.
@iabdalkader will have to help with that.
