Not able to get my H7 Plus to connect to the IDE.
Knowns:
-It flashes blue as if running the python script.
-It appears in Device Mgr (and Windows) as a storage device.
-It was working the last time I tried it, probably a year ago.
-Running the latest IDE version 4.4.7 on Win10.
What I tried:
-Changing the cable didn’t fix it.
-Uninstalling/installing older IDE versions didn’t fix it (3.0.3 and 4.0.1; back to 4.4.7 now).
-Running the “Is it bricked”>reconnect with RST & BOOT jumper process failed (continuous error message in the popup details
-Trying to connect now and it says a board in DFU mode was detected. I tried installing latest (4.5.9) with erase internal file system unchecked and it said it was successful. I then removed the jumpers, disconnected/reconnected the board as instructed, and the green LED keeps blinking while the IDE still said “Reconnect your OpenMV Cam.” I hit Cancel after 10-12 min. which brings me back to the “is it bricked” question.
It does not appear in Device manager anymore. Here is the detail popup for flashing:
Any obvious things to try?
On a side note: Is there a place to find specific firmware versions? I couldn’t find them on the github site.
