I’ve had some luck using the Blues Wireless Notecard for connectivity. They also offer host firmware updates over the air for STM32
and I have been trying to get that working.
I’ve hit a few stumbling blocks and wanted to confirm a few things:
- Are DFU updates possible through the pins only?
This is possible right? We’re not just restricted to USB via the IDE, right?
- Does the DFU update use UART Bus #1 (TX/P1, RX/P0)?
I think this is right because I have managed to corrupt my firmware once already with these pins and had to recover via the IDE.
- Which firmware binary should I use?
Blues recommends wrapping firmware binaries, but I’m not sure if this applies to OpenMV firmware builds.
I’ve tried with and without binpack
with the firmware.bin
, firmware.dfu
and openmv.bin
files from my builds. firmware.bin
installs fine via the IDE.
Do you think I’m using the wrong file? Maybe the wrong memory_addr
param for binpack
? I can send more specific errors in follow-up posts if necessary, but here are few of the errors I’ve seen:
Error (cannot update host: cannot allocate 131072 bytes {memory})
Error (cannot update host: page-by-page erase failed (check max pages device supports): timeout)
