Connection issues Mac <-> H7 PLUS
Hi all,
I don’t know if it started with the latest update of the Cam that was available or perhaps the update of MacOS 13.1.1 (or maybe neither), but recently I have a lot of difficulty connecting to the Cam from the IDE.
I can usually connect to the cam if I plug it in and directly connect through it using the IDE. However, lately it is the case that about 80% of the times that I hit the STOP button, the terminal stops showing output but the cam continues working. It doesn’t stop and I can only reconnect it by unplugging it, wait a few seconds, and then start anew.
I remember this used to be work smoothly. Is there a known issue with this? Is there anything I can do to troubleshoot myself?
Regards
Martin
Note that the cam is not bricked as unplugging and replugging it works.
Also I have connected UART cables through the WiFi shield for communication with a micro:bit. I am not sure if that would interfere with things?
Hmm, it appears that it works better with the helloworld.py… is it possible that open sockets, etc, cause problems?
I found this: UART read makes OpenMV IDE hang - #7 by airborne from 2017
I am indeed using readline() for the UART connection and not any()… would this be the cause of my behaviour?
I have made an command in my application to activate machine.reset() on the board; when sending this, it seems that I can reconnect appropriately to the IDE again. So I do think it’s an interrupt issue but this workaround is acceptable :slight_smile:
Hi, I’ll be doing IDE updates starting in May and hope to modernize everything in the IDE. This may fix your issues.
