I have a h7, that works perfectly with a Mac Mini running Catalina. My 5,1 Mac Pro running Mojave and the latest IDE connects, then disconnects after 10 seconds. H7 shows up on the desktop as a mounted disc. Same USB cable for both, tried different USB ports. Any suggestions?
Is the camera directly connected to the laptop? The IDE will only do that when it doesn’t get a response over serial.
The driver we use is pretty standard… not sure what the issue is. Maybe Mojave changed something.
Can you create a bug ticket on the openmv-ide github?
