Where do I find a descrition on which jumpers I need to connect in order to be able to firmware update?
I have an RT1062 board with a Genx320 sensor. My Firmware is OpenMV v4.5.9. I understand that it needs to be at least 4.7 to make it work. I also understand that I need to connect the SBL to the 3.3V pin to be able to update the firmware. Is there a good description how this can be done? Where are this pins?
Hi, you don’t need to use SBL unless you need to recover the board from being bricked. Just click on the firmware out of data button on the status bar and the IDE will update your firmware. Use the latest IDE.
