Factory filesystem boot mode for OpenMV RT1062
Hi! As far as i saw in the docs, to put in DFU mode the camera, i should connect 3.3V to the BOOT 0 Pin. However, in the RT1062 this pin does the function of WAKE and i don’t find the way of doing it.
Any ideas? Thank you in advance!
There’s an SBL pin on the RT1062. It’s right next to the 3.3V pin near the USB connector.
The location of the pin changed.
Is it possible to update the firmware from the OpenMV IDE?
Yes, the IDE has the latest version of NXPs tools installed. If they are not working then there’s something else going on with your system not allowing the RT1062 to be programmed.
The problems with RT1062 started after installing the new version of OpenMV IDE 4.7. The OpenMV program offered to update the firmware after launch. An error appeared after the update attempt. I tried to update on two more computers, the result is the same.
Hi, is the issue fixed now?
