When i put SD card in my Portenta i getting strange image. Without SD card it’s ok. I tried use different SD cards and i still have same problem.
Hi, we’re about to release a new Arduino Portenta firmware and IDE. Please wait until this release comes out. It may fix your issue.
Strange how ? Can you attach some screenshots ? Also which firmware are you using ?
Hi, the latest firmware is actually 3.6.9 you should try that first.
A firmware update solved my problem. Thanks
Talking about the SD card. I put mine in but I think it is unformatted, so I have 2 questions:
- How to I get it out, it feels locked or at least really tight. Is it just pull hard. I don’t think it is push then pull like some other sd cards. Looks like it might have a little lock. Any ideas.
\ - Can I format it while it is in the Portenta Vision Shield slot?
You just pull it out.
Yes, using your desktop OS.
Hi, I also found a similar problem as shown in matt992’s pictures.
Would it be possible if you could update the OpenMV IDE to 3.6.9?
After I installed the latest version, 3.9.0, the problem is solved!!!
