Hoping there is a solution to accessing the SD card on the breakout board for the portenta. The library in OpenMV micropython seems to be missing the machine SD components.
Regards,
Roy
Regards,
Roy
Access it how ? It’s connected the same bus used on the vision shield, so it should be working out of the box.
Ah, my mistake. I can see when I run the below, the file structure. I was so focused on how to mount it, I didn’t realise it didn’t need to be. Thanks!
print(os.listdir())
