Oh gosh, I’m sorry, my head has been everywhere. The script ran, but I had to debug it cause the functions being called on the camera are not returning anything.
I put the same ports on both interfaces, and still, nothing happened.
I’'ll leave both scripts here to see if you could kindly see if something is wrong.
Camera: (main.py)
# Image Transfer - As The Remote Device
# This script is meant to talk to the "image_transfer_jpg_as_the_controller_device.py" on your computer.
# This script shows off how to transfer the frame buffer to your computer as a jpeg image.
import image, network, omv, rpc, sensor, struct
# Turn off the frame buffer connection to the IDE from the OpenMV Cam side.
# This needs to be done when manually compressing jpeg images at higher quality
# so that the OpenMV Cam does not try to stream them to the IDE using a fall back
# mechanism if the JPEG image is too large to fit in the IDE JPEG frame buffer on the OpenMV Cam.
omv.disable_fb(True)
# The RPC library above is installed on your OpenMV Cam and provides mutliple classes for
# allowing your OpenMV Cam to be controlled over USB or WIFI.
# Choose the interface you wish to control your OpenMV Cam over.
# Uncomment the below line to setup your OpenMV Cam for control over a USB VCP.
interface = rpc.rpc_usb_vcp_slave(port=/dev/ttyACM0)
# Uncomment the below line to setup your OpenMV Cam for control over WiFi.
# * ssid - WiFi network to connect to.
# * ssid_key - WiFi network password.
# * ssid_security - WiFi security.
# * port - Port to route traffic to.
# * mode - Regular or access-point mode.
# * static_ip - If not None then a tuple of the (IP Address, Subnet Mask, Gateway, DNS Address)
# interface = rpc.rpc_wifi_slave(ssid="",
# ssid_key="",
# ssid_security=network.WINC.WPA_PSK,
# port=0x1DBA,
# mode=network.WINC.MODE_STA,
# static_ip=None)
# Call Backs
# When called sets the pixformat and framesize, takes a snapshot
# and then returns the frame buffer jpg size to store the image in.
# data is a pixformat string and framesize string.
def jpeg_image_snapshot(data):
pixformat, framesize = bytes(data).decode().split(",")
sensor.set_pixformat(eval(pixformat))
sensor.set_framesize(eval(framesize))
img = sensor.snapshot().compress(quality=90)
return struct.pack("<I", img.size())
def jpeg_image_read_cb():
interface.put_bytes(sensor.get_fb().bytearray(), 5000) # timeout
# Read data from the frame buffer given a offset and size.
# If data is empty then a transfer is scheduled after the RPC call finishes.
# data is a 4 byte size and 4 byte offset.
def jpeg_image_read(data):
if not len(data):
interface.schedule_callback(jpeg_image_read_cb)
return bytes()
offset, size = struct.unpack("<II", data)
return memoryview(sensor.get_fb().bytearray())[offset:offset+size]
# Register call backs.
interface.register_callback(jpeg_image_snapshot)
interface.register_callback(jpeg_image_read)
# Once all call backs have been registered we can start
# processing remote events. interface.loop() does not return.
interface.loop()
Master:
# Image Transfer - As The Controller Device
# This script is meant to talk to the "image_transfer_jpg_as_the_remote_device_for_your_computer.py" on the OpenMV Cam.
import io,rpc, serial , socket, struct, sys
from serial.tools import list_ports
# Fix Python 2.x.
try: input = raw_input
except NameError: pass
# allowing your OpenMV Cam to control over USB or WIFI.
# Choose the interface you wish to control an OpenMV Cam over.
# Uncomment the below lines to setup your OpenMV Cam for controlling over a USB VCP.
# * port - Serial Port Name.
print("\nAvailable Ports:\n")
for port, desc, hwid in serial.tools.list_ports.comports():
print("port: {} : {} [{}]".format(port, desc, hwid))
sys.stdout.write("\nPlease enter a port name: ")
sys.stdout.flush()
interface = rpc.rpc_usb_vcp_master(port=input())
print("")
sys.stdout.flush()
# Uncomment the below line to setup your OpenMV Cam for controlling over WiFi.
# * slave_ip - IP address to connect to.
# * my_ip - IP address to bind to ("" to bind to all interfaces...)
# interface = rpc.rpc_wifi_or_ethernet_master(slave_ip="xxx.xxx.xxx.xxx", my_ip="", port=0x1DBA)
# Call Back Handlers
def get_frame_buffer_call_back(pixformat_str, framesize_str, cutthrough, silent):
if not silent: print("Getting Remote Frame...")
result = interface.call("jpeg_image_snapshot", "%s,%s" % (pixformat_str, framesize_str))
if result is not None:
size = struct.unpack("<I", result)[0]
img = bytearray(size)
print(1)
if cutthrough:
# Fast cutthrough data transfer with no error checking.
# Before starting the cut through data transfer we need to sync both the master and the
# slave device. On return both devices are in sync.
result = interface.call("jpeg_image_read")
# GET BYTES NEEDS TO EXECUTE NEXT IMMEDIATELY WITH LITTLE DELAY NEXT.
# Read all the image data in one very large transfer.
interface.get_bytes(img, 5000) # timeout
# Slower data transfer with error checking.
# Transfer 32 KB chunks.
chunk_size = (1 << 15)
if not silent: print("Reading %d bytes..." % size)
for i in range(0, size, chunk_size):
ok = False
for j in range(3): # Try up to 3 times.
result = interface.call("jpeg_image_read", struct.pack("<II", i, chunk_size))
img[i:i+chunk_size] = result # Write the image data.
if not silent: print("%.2f%%" % ((i * 100) / size))
ok = True
break
if not silent: print("Retrying... %d/2" % (j + 1))
if not ok:
if not silent: print("Error!")
return None
return img
if not silent: print("Failed to get Remote Frame!")
return None
sys.stdout.flush()
# You may change the pixformat and the framesize of the image transfered from the remote device
# by modifying the below arguments.
# When cutthrough is False the image will be transferred through the RPC library with CRC and
# retry protection on all data moved. For faster data transfer set cutthrough to True so that
# get_bytes() and put_bytes() are called after an RPC call completes to transfer data
# more quicly from one image buffer to another. Note: This works because once an RPC call
# completes successfully both the master and slave devices are synchronized completely.
img = get_frame_buffer_call_back("sensor.RGB565", "sensor.QQVGA", cutthrough=True, silent=False)
print(2)
if img is not None:
print("sent-")
#print(clock.get_fps())
