Hi again trying to expand the capabilities of the portenta + vision shield by using the 5 pin I2C connecter to attach an APDS9960 (proximity sensor) in combination with an additional external pwm IR LED. Seems like the library GitHub - liske/python-apds9960: Python APDS-9960 Library should do the trick but I’m at bit at a loss with how to connect the LED when the vision shield is attached. Do the 80 pin connectors use all of the available pins or is there still a way to connect a led?
Would I be able to use the I2C connecter to slave a nano 33 sense?
Can the nano 33 be powered via the charging connecter?
Would it be possible in the future to run a tf model on the m4?
Sorry for all the varied and potentially dumb questions, new to this board and appreciate any help or guidance available as the documentation seems sparse.
