Hi, just wanted to check if Arduino Portenta H7 + Vision Shield can support an SPI camera or will there be a conflict. Any experience in trying this out?
PC
PC
Hi, you need to trace the connections from the Portenta schematic and the Vision shield and determine if a SPI bus is free. I believe I’ve previously provided details to you on how to trace the pins.
Assuming enough pins for SPI are free and available then you can use a SPI bus at the same time.
Ah, thanks for confirming!
