When i connect openMV H7 plus cam to the PC. the green light contineusly keeps blinking and the cam becomes hot after a couple of mins. but the IDE doesnt detect any usb, neither my computer ports detect anything. i tried it with multiple computer and multiple USB cables. same problem persists.
I have also tried force boot by connecting jumper wires at boot to reset pins, the ide temporeryly resets and downloads the latest firmware, but while downloading, it again disconnects from the pc. and the problem persists
Hi, it sounds like the board is never exiting the bootloader.
If the system crashes and then instantly resets this will be the case. The only thing I can think of is that there is an issue with the sdram causing it to be in a reset loop as the MCU and USB work to get the download and flashing green light.
We don’t repair boards. It’s just too challenging for their cost.
However, can you try powering it with 3.3V from the 3.3V pin? We’ve had people kill the 5V to 3.3V LDO onboard. This part doesn’t die by accident… as I’ve had several H7 Pluses that have not died and been in use for years. Typically, the issue is always overvolting it via VIN.
Applying the 3.3V via the pin on the header skips the reg and may make it come back to life.
