OpenMV H7 plus R3 Overheating
Hello, I have Two OpenMV H7 Plus , and both of them overheat when i using the camera , they operate fine , but the overheating is a problem , someone have a same problem , how was fix it ?
That’s not a normal problem. What environment are you using them in? They do get warm. However, they should not overheat.
I read the internal temp via the onboard temperature sensor and got a temp 49 c , is a correct temp ?
Yeah, that would be inside the die area. However, that’s nowhere near the maximum temperature limit.
I was do more test and got temp 60 C on the uC , i guess is a correct temp, the max value is 85 C, right?
85 is the ambient temp max. The junction temp on the chip itself from its internal temperature sensor can go higher.
