OpenMV cam H7 plus not detected
Hello everybody.
I am using an OpenMV cam H7 plus for the first time and the IDE does not recognize it. When connecting it to usb it flashes green and then it flashes blue and it stays that way. I followed all the instructions and it is still not detected.
Try a different USB cable.
Your cable is probably power only. Use a different cable with data support.
Thank you. Now it is working fine.
Muchas gracias.
