Meaning of Onboard LED Colors on RT1062
I’m curious about the meaning of the colors of the onboard LED located at the top right of the RT1062 board, which we cannot control. I know that if it is green, the system is running properly. However, I couldn’t find any docume
ntation regarding what it means when the LED lights up blue or red. Does anyone know what these colors indicate?
Thank you!
Hi, I’ll fix the webpage to add what the colors means.
The red light means that the battery is charging and the blue light means you are receiving power from VIN versus USB.
Green means that power is available from VIN or USB. The green LED will not lightup when powered from a battery.
