Cam RT1062 Supply
We have an application with the RT1060 using the VIN pin to supply the board with 4.6 V.
We are getting some fails that require switching off an on the board to function again.
According to the description in the pinout info the voltage in that pin must be in the range of 3.6 to 5.0.
Can we be confident that our supply is ok?
Regards
Hi Alfonso, 4.6V should be fine to use. If you are using the RT1062 V4 board, please note that the ideal diode onboard sometimes browns out when switching between USB and VIN depending on if the camera’s 3.3V rail is loaded with extra logic. This was fixed on the V5. If you are not switching voltage supplies by plugging in USB while being powered via VIN then there may be an issue with your power supply.
