I have an issue with the power supply on the OpenMV RT1062 (Legacy). Firmware 4.5.9, IDE 4.4.4
Here’s what happens:
- I connect the OpenMV with USB to my Macbook Pro and run code.
- The code tells the robot to supply 5V on the VIN pin for the OpenMV. (It also puts 3v3 on the 3v3 pin).
- I stop the script, the robot stops supplying power on Vin, but maintains 3v3.
- I restart the script
- The robot starts supplying 5V on the VIN pin again, and maintains 3v3.
- The OpenMV board crashes hard: I lose USB connection, unable to reconnect. The power button on the OpenMV does not reset it anymore. Only disconnecting all wires works.
If I do the exact same scenario with a voltage meter on the OpenMV Vin pin, everything is fine. I can stop and restart at will. Since the Vmeter has a non-zero resistance, I imitated that circuit by adding a 1MOhm resistor on the OpenMV between Vin and Gnd. This also works perfectly and it is my workaround. What I don’t like is that I don’t understand the reason why this workaround works. I also feel queasy about shorting Vin all the time.
Do you have a better solution?
