Hi!
Just a friendly suggestion for future boards. Vias under image sensor are bleeding outside light giving strange artifacts on image.
I have painted them over, so the problem is solved ![]()
Best regards
Hi!
Best regards
Can you put this into the github as an error?
Any suggestions on how to fix that ? Note the vias are painted over already with the stop mask, but it doesn’t seem to stop bleeding completely.
Hi!
I have posted issue on github as requested.
As how to solve this problem… I guess the easiest way is maybe to apply solder over vias?
Best regards
