I don’t know to get rid of this ImportError when there is an actual module named “Command” and the IDE wasn’t complaining about it before. For some reason it all of a sudden can’t find the module. Why does this happen?
There’s a module called Command.py on the root folder of your camera correct?
Yes. To fix the problem I had to install a new SD card. Why it fixed the problem, I don’t know. It was a brand new SD card,
The system was probably having a hard time reading the card.
