Hi! Newbie here, I got my hands on the OpenMV cam H7 and it was working great, tried out some examples which were really helpful. Then I updated the firmware to the latest version 4.1.2, and now the camera looks like it has a green filter when the pixel format is set to RGB565. Anything suggestions to remedy this? Thanks.
Hmmm, wait there might be a software regression. I just tested the firmware on an H7 pure thermal with the same camera and this does not happen.
Can you post a picture of your board?
Hi, I have an H7 Plus camera and I don’t get a green image.
# Untitled - By: kwagyeman - Sun Dec 5 2021
import sensor, image, time
Please run this:
import omv
print(omv.arch())
Should print: OMV4P H7 32768 SDRAM
If it prints something else it means you have the wrong firmware onboard.
Okay so I definitely installed the wrong firmware somehow. I was able to get the right one and my problem is fixed, thank you for your help!
