I have installed OpenMV IDE: 4.0.12 on a macOS Ventura (13.2) and flashed the Arduino Giga R1 with OpenMV firmware v4.5.0. I am able to run example scripts from the IDE. However, I do not see any flash drive mounted. When I plug in the Giga R1 USB cable I see the message:
“The disk you attached was not readable by this computer”.
To test, I tried the Micropython firmware provided by Arduino and flashed it using the command: dfu-util -w -a 0 -d 2341:0366 -D GIGAR1_MP_FW.dfu
I can see a mounted mass storage drive “GIGA”. So I guess it has some issue with the OpenMV firmware.
How big is the drive that you see with the MicroPython firmware ? The older releases used the internal flash, not the QSPI one. Can you try the latest stable build 1.21.0 from here ?
Yes this confirms it, for some reason only the internal flash storage works on your board/OS not the QSPI, both MicroPython 1.21.0 and our firmware use the QSPI storage. I have a Giga H7 with me and it mounts the QSPI storage just fine, so it’s either your board or the OS that’s the issue, I don’t have a Mac to test with but I will ask someone to test it and get back to you.
I have flashed it with the latest OpenMV firmware again and connected it to the Raspberry Pi 4.
dmesg output:
[ 148.325483] usb 1-1.1: new full-speed USB device number 3 using xhci_hcd
[ 148.719726] usb 1-1.1: New USB device found, idVendor=2341, idProduct=0466, bcdDevice= 2.00
[ 148.719760] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 148.719776] usb 1-1.1: Product: Giga Virtual Comm Port in FS Mode
[ 148.719791] usb 1-1.1: Manufacturer: Arduino
[ 148.719804] usb 1-1.1: SerialNumber: 3956374F3132
[ 148.789831] cdc_acm 1-1.1:1.0: ttyACM0: USB ACM device
[ 148.789923] usbcore: registered new interface driver cdc_acm
[ 148.789929] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 148.796495] usb-storage 1-1.1:1.2: USB Mass Storage device detected
[ 148.797358] scsi host0: usb-storage 1-1.1:1.2
[ 148.797765] usbcore: registered new interface driver usb-storage
[ 148.803667] usbcore: registered new interface driver uas
[ 149.833545] scsi 0:0:0:0: Direct-Access MicroPy pyboard Flash 1.00 PQ: 0 ANSI: 2
[ 149.835606] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 149.836358] sd 0:0:0:0: [sda] 30976 512-byte logical blocks: (15.9 MB/15.1 MiB)
[ 149.836731] sd 0:0:0:0: [sda] Write Protect is off
[ 149.836751] sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00
[ 149.837132] sd 0:0:0:0: [sda] No Caching mode page found
[ 149.842967] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 149.859063] sda: sda1
[ 149.863908] sd 0:0:0:0: [sda] Attached SCSI removable disk
fdisk -l output:
Disk /dev/sda: 15.13 MiB, 15859712 bytes, 30976 sectors
Disk model: pyboard Flash
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x00000000
Device Boot Start End Sectors Size Id Type
/dev/sda1 256 30975 30720 15M 1 FAT12
I am accessing the RPI4 headless over ssh so can’t see if it is auto mounted. How do you check or mount it using command line? I tried mount -t vfat /dev/sda1 /mnt but not working.
I think March would make it an early dev sample, not sure, about the QSPI, it might not be faulty, although everything points to an issue with it, here’s mine do you have a different one maybe ?
12:22:42.783 -> Available partition schemes:
12:22:42.783 ->
12:22:42.783 -> Partition scheme 1
12:22:42.783 -> Partition 1: WiFi firmware and certificates 1MB
12:22:42.783 -> Partition 2: OTA and user data 13MB
12:22:42.783 ->
12:22:42.783 -> Partition scheme 2
12:22:42.783 -> Partition 2: OTA 5MB
12:22:42.783 -> Partition 3: User data 8MB
12:22:42.783 ->
12:22:42.783 -> Do you want to use partition scheme 1? Y/[n]
12:22:42.783 -> If No, partition scheme 2 will be used.
12:22:50.793 ->
12:22:50.793 -> WARNING! Running the sketch all the content of the QSPI flash will be erased.
12:22:50.793 -> Do you want to proceed? Y/[n]
12:22:55.721 ->
12:22:55.721 -> QSPI Flash formatted!
12:22:55.721 -> It's now safe to reboot or disconnect your board
Here I answered Yes and Yes.
Then try the USB Storage example → AccessFlashAsUSBDisk, you should see 2 volumes mounted.
Yes one of them should be 1MBs the other ~15MBs, so it seems your QSPI is fine, I’m not sure why it’s not working with MicroPython then. Can you please send a picture of the board ?
Also, can you try the attached MicroPython firmware see if it works. firmware.dfu (1.0 MB)
