Difficulties Connecting
Back to fail msg.
Windows 10 - 64 bit
jumper connected.
Hmmm, you’d only get that if the DFU update hung. DFU should basically error out immediately if there’s a problem or work. Not hang.
Okay, let me send out another board to you. I have an extra one at home with me I can provision and test to make sure it works before sending it to you. Please email openmv your address.
Um, however, in the email, can you confirm that windows sees a device when you plug the camera into your computer in DFU mode? Windows should pop up some text about an STM DFU device being attached.
I hear the Windows connection tone but there’s no message.
You should see this in the device manager.
If that’s the case I’m not sure why you are having problems. DFU should work.
Anyway, I can provide another Cam program and tested by me.
It says "Unknown USB Device (Device Descriptor Request Failed)
It only sees the board with the jumper on.
Yeah… that shouldn’t happen. Um, anyway, please send me your address via email so I can send a replacement.
I sent you my address. Let me know if you can’t find it.
Norm
Hi, I didn’t get an email. Please send it to openmv@openmv.io.
On the way.
Norm
Got it and everything seems to be working.
