Im on MacOS and when i go to tools and try to click save open script to cam its blacked out and cant click it. Can anyone help me?
It’s because the disk is not found in OpenMV IDE, either it’s not mounted by your PC or the IDE didn’t discover it. Try disconnecting and reconnecting via the button in the IDE.
ive tried it but its still blacked out
i can run code on it but it doesnt save
Does a disk appear when the camera is plugged into USB?
no it doesnt
I’m not sure what may be wrong then, maybe you need to update your firmware. Please click on the firmware version label shown in the status bar of the IDE when you connect to the camera, follow the prompts to update the firmware, click the erase flash disk option, and also the reset romfs option. This should factory reset it.
