Hi, I try to change LCD display type by “lcd.update_touch_points()”.
But it will show OSError when OpenMV IDE run about 10 seconds.
OSError : Failed to update the number of touch points
Code :
import sensor, fir, image, time, lcd, math, pyb
from vl53l1x import VL53L1X
threshold_list = [(200, 255)]
i2c = I2C(2)
distance = VL53L1X(i2c)
time.sleep_ms(50)
fir.init(fir.FIR_LEPTON)
fir_img = sensor.alloc_extra_fb(fir.width(), fir.height(), sensor.GRAYSCALE)
time.sleep_ms(50)
lcd.init(lcd.LCD_DISPLAY_WITH_HDMI, framesize=lcd.FWVGA, refresh=60)
alpha_pal = image.Image(256, 1, sensor.GRAYSCALE)
for i in range(256): alpha_pal[i] = int(math.pow((i / 255), 2) * 255)
to_min = None
to_max = None
def map_g_to_temp(g):
return ((g * (to_max - to_min)) / 255.0) + to_min
i=3
if(lcd.update_touch_points()==1):
img = fir.snapshot(x_size = 640, y_size = 480, color_palette = fir.PALETTE_IRONBOW, copy_to_fb = True)
img.draw_string(4, 0, 'Distance: %d mm' % distance.read(), color = (255, 255, 255), mono_space = False, scale = 2)
lcd.display(img, x_size = lcd.width(), hint = image.BILINEAR)
i=1
elif(lcd.update_touch_points()==2):
i=2
elif(lcd.update_touch_points()==3):
# ta: Ambient temperature
# ir: Object temperatures (IR array)
# to_min: Minimum object temperature
# to_max: Maximum object temperature
fir.draw_ir(fir_img, ir, color_palette = None)
fir_img_size = fir_img.width() * fir_img.height()
# Find IR Blobs
blobs = fir_img.find_blobs(threshold_list,
pixels_threshold = (fir_img_size // 100),
area_threshold = (fir_img_size // 100),
merge = True)
# Collect stats into a list of tuples
blob_stats = []
for b in blobs:
blob_stats.append((b.rect(), map_g_to_temp(img.get_statistics(thresholds = threshold_list,
roi = b.rect()).mean())))
x_scale = img.width() / fir_img.width()
y_scale = img.height() / fir_img.height()
img.draw_image(fir_img, 0, 0, x_scale = x_scale, y_scale = y_scale,
color_palette = sensor.PALETTE_IRONBOW,
alpha_palette = alpha_pal,
hint = image.BICUBIC)
# Draw stuff on the colored image
for b in blobs:
img.draw_rectangle(int(b.rect()[0] * x_scale), int(b.rect()[1] * y_scale),
int(b.rect()[2] * x_scale), int(b.rect()[3] * y_scale))
img.draw_cross(int(b.cx() * x_scale), int(b.cy() * y_scale))
for blob_stat in blob_stats:
img.draw_string(int((blob_stat[0][0] * x_scale) + 4), int((blob_stat[0][1] * y_scale) + 1),
'%.2f C' % blob_stat[1], mono_space = False, scale = 2)
# Draw ambient, min and max temperatures.
img.draw_string(4, 0, 'Lepton Temp: %0.2f C' % ta, color = (255, 255, 255), mono_space = False, scale = 2)
img.draw_string(4, 18, 'Min Temp: %0.2f C' % to_min, color = (255, 255, 255), mono_space = False, scale = 2)
img.draw_string(4, 36, 'Max Temp: %0.2f C' % to_max, color = (255, 255, 255), mono_space = False, scale = 2)
img.draw_string(4, 54, 'Distance: %d mm' % distance.read(), color = (255, 255, 255), mono_space = False, scale = 2)
i=3
elif(i==1):
elif(i==2):
elif(i==3):
# Find IR Blobs
merge = True)
blob_stats = []
for b in blobs:
for b in blobs:
