I am unable to video feed via the wireless tv shield. I am using the example code. My skydroid 5.8 receiver (works with my fpv rc car) picks up the signal from the tv shield but nothing displays - black image. The image goes back to noise once the tv shield is powered down.
Yeah, that’s correct, can you verify the solder job is good on all the pins and etc?
Also, can you make a script which sets the channel value: tv — tv shield driver — MicroPython 1.19 documentation and then reads it back? Use channel 2. If you can set the channel and read back 2 then the SPI bus is working on the sensor. If not then there’s some problem.
