Finally got around to installing the global shutter module on my H7. Seems to function, but why the horizontal lines in the image? Is it not seated correctly or ? ?
Hello
That looks to me like its just a very low resolution image.
Can you post your code/script?
Felix
thresholds = [(10, 48, -10, 10, -10, 10), # generic_red_thresholds
(10, 48, -10, 10, -10, 10), # generic_green_thresholds
(10, 48, -10, 10, -10, 10)] # generic_blue_thresholds
sensor.set_framesize(sensor.QVGA) # modulates min blob size
sensor.skip_frames(time = 300) # Use this after every register change 10 frames 300mS default
print(“New exposure == %d” % sensor.get_exposure_us())
print(“Sensor ID == %d” % sensor.get_id())
print(“Sensor Height == %d” % sensor.height())
print(“Sensor Width == %d” % sensor.width())
event_count = 0 # actually a blob counter
for blob in img.find_blobs(thresholds, pixels_threshold=10, area_threshold=70):
event_count = event_count + 1
if blob.elongation() > 0.5:
img.draw_edges(blob.min_corners(), color=(55,255,10))
# img.draw_line(blob.major_axis_line(), color=(255,255,0))
# img.draw_line(blob.minor_axis_line(), color=(255,255,0))
# img.draw_rectangle(blob.rect())
# img.draw_keypoints([(blob.cx(), blob.cy(), int(math.degrees(blob.rotation())))], size=10)
print(“FPS == %f” % clock.fps()) # looks like %d is for integers
print(blob.cx(), blob.cy())
print(“BLOBs == %d” % event_count) # Use %f for floats
# print(event_count)
Please reformat your post using the code formatting tags, this is almost impossible to read!
This line sets the resolution to 1/4 of VGA, i.e. 320 x 240 pixels:
You are not showing the full picture in your initial post, but considering you are setting it to QVGA the part I see seems to be about right. You can use the global shutter in full VGA resolution as it’s grayscale, so the picture indeed fits into memory even on the H7, then the quality should get better (but FPS may go down).
Please keep the focus. Are those horizontal lines in the sample of the picture an artifact of socketing or is something else wrong with the sensor?
Seems I got on the wrong track…
You can always try to re-seat it (have you?) to see if that changes anything.
I’m getting similar lines (not static, more flickering) when I use a high(er) gain on the sensor. So far I suspected noise from the USB, or the DCDC or the MCU to be the reason behind it, but did not investigate it much further. For me it’s not an issue as I don’t use the high gain to keep imager noise low, but you could try to reduce gain to check if that changes anything.
Having a lower gain but a longer exposure time generally results in better image quality anyway.
The H7 isn’t the best designed board for image quality. We fixed this on the upcoming RT1060. There’s just a lot of noise on the 3.3V supply that couples into the sensor. As such, it’s not going to be perfect. However, it shouldn’t affect the usability of the system. If you want better image quality increase the exposure.
