Where is the 100fps IR tracker script?
in reference to the following youtube video from OpenMV:
100+ FPS IR LED Tracking with the OpenMV Cam H7 Plus - YouTube
Is this script posted somewhere or available in the OpenMV IDE? Thanks,
Found it - it is under Examples → Camera → Readout Control
I am using an H7 Plus and the OV5640 but no luck hitting 100fps yet.
Hi, you should easily be able to get 100 FPS. Just use your phones LED light and wave it in front around the camera.
kwagyeman,
Thanks, I did eventually get > 100fps - It was a matter of playing with the area parameters and the search vs. tracking resolution. I was tracking a laser spot on a distant wall.
Thank you so much for your excellent product and product support work ethic!
