I would like to configure my Portenta H7 with an Webserver that provides HTTPS connection.
The key and cert files are available and readable.
Unfortunatly I got the follwing error message:
File “”, line 64, in
File “ssl.py”, line 1, in wrap_socket
File “ssl.py”, line 1, in load_cert_chain
OSError: [Errno 2] ENOENT
I use the following code:
import usocket as socket
except:
import socket
import time, network, gc, ssl, os
gc.collect()
# Load SSL certificates
with open('/certs/server.crt', 'r') as f:
cert = f.read()
with open('/certs/server.key', 'r') as f:
key = f.read()
SSID ='OPENMV_AP' # Network SSID
KEY ='1234567890' # Network key (must be 10 chars)
HOST = '' # Use first available interface
PORT = 8080 # Arbitrary non-privileged port
# Init wlan module in AP mode.
wlan = network.WLAN(network.AP_IF)
wlan.deinit()
wlan.config(essid=SSID, channel=11, password=KEY)
global var1
global var2
var1 = "Variable 1: 12345"
var2 = "Variable 2: 67891"
print("Connect to: ", wlan.ifconfig())
while (len(wlan.status("stations")) == 0):
print("Waiting for a station to connect...")
print("Station connected", ':'.join(["%x"%(x) for x in wlan.status("stations")[0][0]]))
def web_page():
html = """<html>
<head><meta name="viewport" content="width=device-width, initial-scale=1"></head>
<body>
<h1>Arduino Portenta WebServer!</h1>
<h2> {var1} </h2>
<h2> {var2} </h2>
</body>
</html>""".format(var1=var1,var2=var2)
return html
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
s.bind(('0.0.0.0', 443)) # Listen on all interfaces, port 443 (HTTPS)
s.listen(5)
# Wrap the socket with SSL
print(key)
print(cert)
s = ssl.wrap_socket(s,server_side=True, key=key, cert=cert, cadata=None, server_hostname=None, do_handshake=True)
print("HTTPS server running on port 443...")
conn, addr = s.accept()
print('Got a connection from %s' % str(addr))
request = conn.recv(1024)
print('Content = %s' % str(request))
response = web_page()
conn.send(response)
conn.close()
Here is the full output. I let print the content of the demo certificate files, to check that the cert files are loaded successfully.
OpenMV v4.5.9; MicroPython v1.23.0-r19; Arduino Portenta H7-STM32H747
raw REPL; CTRL-B to exit
>OKConnect to: ('192.168.4.1', '255.255.255.0', '192.168.4.1', '0.0.0.0')
Station connected 4:d6:aa:19:36:e
-----BEGIN ENCRYPTED PRIVATE KEY-----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-----END ENCRYPTED PRIVATE KEY-----
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
File "<stdin>", line 64, in <module>
File "ssl.py", line 1, in wrap_socket
File "ssl.py", line 1, in load_cert_chain
For me is not exactly clear, which file could not found or is unable to load.
Thanks.
