HTTPS connections for Let's Encrypt Certs?
Hey Folks,
I have an OpenMV H7 Plus with a standard Wifi Shield.
Has anyone figured out how to send REST requests to a site that uses a “Let’s Encrypt” free certificates? I have an OpenMV H7 Plus with a standard Wifi Shield. When I run the stock “Wifi-Shield/http_client_ssl.py” it connects to host “www.google.com” just fine, but when I change the host to my server (with a Let’s Encrypt certificate) it breaks with an “OSError: [Errno 5] EIO”. I know my site works and has a valid certificate, it gets a “green” certificate badge in chrome…
Am I missing some obvious thing?
Eric
After looking at the output, I guess I should mention that the actual error code is: mbedtls_ssl_handshake error: -7780 When I look up that code I find:
from “Mbed TLS - Trusted Firmware
#define MBEDTLS_ERR_SSL_FATAL_ALERT_MESSAGE -0x7780
A fatal alert message was received from our peer.
No clue, but, MBEDTLS_ERR_SSL_FATAL_ALERT_MESSAGE - Google Search
Might have an answer.
Argh!
Ok, I just double checked my cert and it does have an issue, turns out you need to use letsencrypt’s fullchain.pem instead of the cert.pem file (on the server).
I am a bonehead, please disregard this thread.
