Hello together,
I would like to visualize measurement values via Web Server functionalities.
Therefore I implemented a WLAN Access Point in my Portenta H7, that provides a Website under the follwing Adress: http://192.168.4.1
Right now, I’m struggeling to implement Python Variables into the HTML output.
In this case the variable “var1” is defined as global variable.
How can I access the content of “var1” in the web_page function?
Thank you.
import usocket as socket
except:
import socket
import time, network, gc
gc.collect()
#https://forums.openmv.io/t/portenta-h7-lite-connected-access-point-not-working/7416
SSID ='OPENMV_AP' # Network SSID
KEY ='1234567890' # Network key (must be 10 chars)
HOST = '' # Use first available interface
PORT = 8080 # Arbitrary non-privileged port
# Init wlan module in AP mode.
wlan = network.WLAN(network.AP_IF)
wlan.deinit()
wlan.config(essid=SSID, channel=11, password=KEY)
global var1
var1 = "12345"
print("Connect to: ", wlan.ifconfig())
while (len(wlan.status("stations")) == 0):
print("Waiting for a station to connect...")
print("Station connected", ':'.join(["%x"%(x) for x in wlan.status("stations")[0][0]]))
def web_page():
html = """<html>
<head><meta name="viewport" content="width=device-width, initial-scale=1"></head>
<body>
<h1>Hello, World!</h1>
<p>
<span>str(var1)</span>
</p>
</body>
</html>"""
return html
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
s.bind(('', 80))
s.listen(5)
conn, addr = s.accept()
print('Got a connection from %s' % str(addr))
request = conn.recv(1024)
print('Content = %s' % str(request))
response = web_page()
conn.send(response)
conn.close()
# http://192.168.4.1
