Is it possible to enable webrepl on nano rp2040 connect with openmv firmware.
It will be possible in the next major firmware update. I pushed WiFi driver fixes, and support for that to micropython, so on the next update we’ll have those fixes back.
Thanks. Is it possible to build openmv myself now from source with webrepl enabled.
No, you’ll need to pull a lot of changes from micropython. You can use micropython now if you like, the latest stable release or nightly builds should have that working.
Okay.
