I am trying to import the ulab module to the OpenMV module but I’m getting an error, although I have installed the latest version of the OpenMV IDE.
I’m importing it as: from ulab import numpy as np
Thanks.
Thanks.
Which camera model are you using? It should be enabled for most cameras.
I’m using OpenMV RT1062
Hi, it looks like this was disabled in the release firmware. We have since fixed this.
Please do Tools->Install Latest Development Release.
Hi, thank you.
I think I have a problem with the connection of the camera to my computer, because I can’t update the firmware. When I click on “Install Latest Development Release” or when I click to the “Firmware Version” box, I’m getting the following message:
Please download this: https://github.com/openmv/openmv/releases/download/development/firmware_OPENMV_RT1060.zip
And install firmware.bin file by going to Tools->Run Bootloader and selecting the firmware.bin file after you unzip it.
If that fails to work something else is wrong. Are you using windows 10/11?
Hi, can you reinstall the IDE? It seems like something is broken with it.
Also, you can try deleting your resources under:
/AppData/Roaming/OpenMV IDE
And just delete that folder. This will force the IDE to re setup its resources.
Hi, I tried deleting the resources and reinstalling the IDE, but it seems the problem is still there. I’ve checked the different tools provided by the IDE interface and I’m facing some problems:
I hope these information to give more evidence about the problem.
Thank you so much in advance
All these issues seem to indicate that the IDE has no access to its resources on your PC.
I haven’t seen this error before.
Can you email us at openmv@openmv.io. I can provide direct help support via a video call. It’s probably something simple to fix and this will go faster if I hop on a call with you.
The issue was resolved by deleting the IDE resources under /AppData/Romain/OpenMVIDE and restarting.
