I’m trying to revive a project and I’m trying to do the following:
- Connect to main controller via UART (since the cam has a harder time being a I2C slave)
- Simple UI with 5-way switch (Incr, decr, prev, next, OK) to adjust several parameters displayed on the tiny LCD with a MCP23008 (8-bit I/O expander) via I2C.
Looking at the H7 and LCD shield pinout, I only have pins P1, P4, P5 and P9 unused.
- Should I use P4 & P5 as UART’s TX & RX to main controller to pass data back and forth?
- Can P5 & P9 be defined as a slow I2C port to the MCP23008 I/O expander? Or is there a better way to do this… like sharing the SPI bus with the LCD and a MCP23S08 instead?
