UART.IRQ Method No Attribute RX_ANY
I tried using the micropython method for implementing uart interrupt handler
class UART – duplex serial communication bus — MicroPython 1.19.1 documentation
and am getting AttributeError UART object has no attribute ‘RX_ANY’.
uart3_baud = 1024000
uart3 = pyb.UART(3, uart3_baud, timeout_char=10)
def uart3IrqHandler(obj):
    print("Type: ", type(obj))
    print(obj.any())
uart3IRQ = uart3.irq(trigger = UART.RX_ANY, priority = 1, handler = uart3IrqHandler)
Is there an uart interrupt handler method for OpenMV?
I’ve never used the IRQ method. That’s a new feature. I’d check the source code:
That’s only available on WiPy platform.
So there is no available interrupt from uart on openmv board?
You have to use the select method:
https://docs.openmv.io/library/uselect.html?highlight=select#module-uselect
