class ExtInt – configure I/O pins to interrupt on external events
“There are a total of 22 interrupt lines. 16 of these can come from GPIO pins and the remaining 6 are from internal sources.”
my code :
# Hello World Example
import sensor, image, time
#import time
from pyb import Pin, ExtInt
from pyb import UART
from pyb import LED
red_led = LED(1)
green_led = LED(2)
blue_led = LED(3)
ir_led = LED(4)
sensor.set_framesize(sensor.VGA) # Set frame size to QVGA (320x240)
uart = UART(3, 19200)
buf=66
data = bytearray(10) # create a buffer
def print_X1(line):
red_led.toggle()#print("X1 is pressed")
ext = ExtInt(Pin('P5'), ExtInt.IRQ_FALLING, Pin.PULL_NONE, print_X1)
ext.enable()
img.draw_rectangle((100,100,100,100),128)#设置坐标(10,10)的像素点为红色(255,0,0)
but when I send “a”,I saw 3 lines print(“X1 is pressed”) on IDE Serial Terminal.
So I think my “ExtInt” codes do not work as UART interrupt.
