import sensor, image, time, machine, pyb
from pyb import LED
from pyb import UART
from pyb import Pin, ExtInt
led = LED(1) # red led
uart = UART(3, 19200)
uart.init(19200, bits=8, parity=None, stop=1)
sensor.sleep(True)
sensor.shutdown(True)
img=0
def whatever(x):
global extint, led,img,REQUEST,ext
ext.disable() #turn off
img +=1# sensor.snapshot()
print(img)
REQUEST = uart.read()
print(REQUEST)
#sensor.reset()
#sensor.snapshot()
led.toggle()
led.toggle()
#print(clock.fps())
ext.enable() #turn on
sensor.sleep(True)
ext = ExtInt(Pin('P5'), ExtInt.IRQ_RISING, Pin.PULL_NONE, whatever)# RX ExtInt
#pc sends the hex data :05 30 01 02 03 04 15.
openmv show me:
1
uncaught exception in ExtInt interrupt handler line 11
MemoryError:
