Hey, Is there any way to access the UART4 via micropython in the IDE ? I can solder a few jumpers to the respective pins. The other 2 UARTs are preoccupied with bluetooth and xbee. ![]()
Thank you in advance,
You have to enable it in the code yourself, rebuild the firmware and flash the image. I don’t enable peripherals that are not broken out.
