I’m trying to receive a string from a device to the openmv H7 Plus.
In this instance I should be receiving “+01.6” - 5 ASCII characters followed by CR but instead I get the byte array b’\xd66\x9b\xe5\x80\xed\ which doesn’t translate to what I expect. Tried lowering the baud rate on both sides but similar outcome. Does OpenMV support RS-232 communication hardware wise?
#uart.init (9600, bits=8,parity=None,stop=1)
import sensor, pyb, time
from pyb import UART
import ustruct as struct
# UART 3, and baudrate.
uart = UART(3, 9600, timeout_char = 1000)
a= uart.read()
print(a)
time.sleep(100)
